Surface pro 4 - clock speed of CPU keeps the same
2016-08-03T03:19:10+00:00
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
2016-08-31T01:11:30+00:00
Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
92 additional answers
    2016-08-25T17:22:16+00:00
    John, Hi,
    I'm finding exactly the same.
    But on reflection, the clock can't actually be at 3.2 GHz 100% of the time or the fans would be howling.
    My suspicion is that this high reported clock speed is a consequence of changes to Windows to accommodate Intel 'Speed Shift', and actual control has been effectively handed from the OS to the CPU.
    http://www.anandtech.com/show/9751/examining-intel-skylake-speed-shift-more-responsive-processors
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-08-25T16:28:55+00:00
    Amen...
    >>Hopefully before Redstone 2
    2016-08-25T15:45:08+00:00
    Thanks Barb. Hopefully before Redstone 2.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-08-25T15:40:05+00:00
    I’ve been told this is a Windows problem, not just impacting Surface devices and that a fix is being worked on by the Windows team. (No ETA, sorry.)
