Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
Happy to help.
After the AU I had to fix a lot of issues. But as for the processor speed, I think your test shows we'll be fine just waiting for a fix. For now, anyway.
I'm getting ~5 hrs after the fix, kind of worse than before (~6 under similar workload?).
Besides I found the frequency control policy much more conservative. It could stay > 2 GHz for 10 minutes when idle (not a strong evidence though).
I've been looking into this, and here's what I found out:
There is a technology called "Intel Speed Shift". In a computer, the OS tells the processor to speed up or slow down depending on current needs. Intel Speed Shift turns control of that over to the processor, and as a result everything is quicker (and theoretically can save a small amount of battery life).
Intel Speed Shift came out in November of last year, but is only now being "turned on" by Windows. "Processor Performance Autonomous Mode" is the on / off switch for Intel Speed Shift.
THEORY:
One of two things is probably happening on our Surface devices.
- Intel Speed Shift is causing the OS to report an incorrect processor speed. Since many CPU diagnostic programs read the speed from the OS, they are also misreporting it. This may be supported by the fact our fans are not running constantly and battery life is nearly the same as it was before the update.
OR
- Intel Speed Shift, or it's connection with Windows, is flawed and causes our CPUs to run too fast.
Therefore, if you apply one of the registry fixes you are merely turning off Intel Speed Shift. This turns control of the CPU back over to Windows and things run as before. Alternately, you can leave it on and wait for a patch to allow Intel Speed Shift and Windows to work together properly.
Personally, since I'm not noticing dramatic heat or battery use increases, I'm waiting a bit to see how MS may update the integration of Intel Speed Shift.
For fun - here are some of the new Win 10 power processor settings:
8baa4a8a-14c6-4451-8e8b-14bdbd197537 – Processor performance autonomous mode (Enable/Disable)
Specify whether processors should autonomously determine their target performance state.
36687f9e-e3a5-4dbf-b1dc-15eb381c6863 – Processor energy performance preference policy (Percent)
Specify how much processors should favor energy savings over performance when operating in autonomous mode.
cfeda3d0-7697-4566-a922-a9086cd49dfa – Processor autonomous activity window (Microseconds)
Specify the time period over which to observe processor utilization when operating in autonomous mode.
4e4450b3-6179-4e91-b8f1-5bb9938f81a1 – Processor duty cycling
Specify whether the processor may use duty cycling
More fun if you're a tech person: http://www.anandtech.com/show/9582/intel-skylake-mobile-desktop-launch-architecture-analysis/7
Thanks for the information...that makes a lot of sense. I just did a small test on my SP4 to check your theories. With Processor Performance Autonomous Mode enabled (Default Setting) I let the SP4 run for 1 hour. The system was largely sitting idle, connected to WiFi with several application open. The CPU was reporting 2.19GHz the entire time. The system was cool the whole time and the fans did not kick on at all. During the hour, the battery dropped 12%.
Then, I used the registry settings to disable Processor Performance Autonomous Mode and let it run for another hour with the same apps running. The system was again largely idle but the processor stayed under 1GHz pretty much the entire time the entire time. The system was cool the whole time and the fans did not kick on at all. Under this scenario, the battery actually dropped 13%. You would think that with the much lower clock speed, the battery drain would be less...but it was actually more.
Of course this was not a scientific test by any means, but it certainly would point to your theory #1 being correct and that the processor is still throttling correctly by using Processor Performance Autonomous Mode, just not reporting correctly to the OS.
THEORY:
OR
