Surface pro 4 - clock speed of CPU keeps the same
2016-08-03T03:19:10+00:00
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
2016-08-31T01:11:30+00:00
Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
92 additional answers
    2016-08-19T00:28:50+00:00
    Ugh. Same here. This explains why I get only a few hours of battery life lately.
    Is Microsoft working on this or aware of the issue? Changing obscure registry keys or "resetting" my machine should not be the default course.
    2016-08-15T21:51:54+00:00
    You want to keep CSEnabled to 1. This is ConnectedStandby -  the feature that enables your WiFi to stay on during sleep state
    2016-08-15T14:23:07+00:00
    Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power
    Change CsEnabled to 0 (should be previously 1)
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\8baa4a8a-14c6-4451-8e8b-14bdbd197537
    Change Attributes to 0 (should be previously 1)
    Restart and now you should have advanced power settings visible in Power Options > Change Advanced Power Settings. Under Processor Power Management you should now see Processor performance autonomous mode. This should be originally Enabled so change to Disabled.
    I followed the above solution and it worked! However, I noticed a side effect: my SP4 when waking up was loosing for about a minute its WiFi connection (after that it returned ok). I went to the Device Manager and I noticed under the Network adapter that the system had added 8 new WAN Miniports I am sure were not there before. I deleted them - rebooted and re appeared!
    Subsequently I went and UN-DID the above solution i.e. returned the registry values to back to their initial setting. Rebooted and WAN miniports gone, waking up from sleep did not loose my wifi connection and most importantly CPU was NOT stuck to 2.47 anymore and working properly!
    2016-08-14T15:20:17+00:00
    CS must be reenebled for sleep modus
