All, After 3 weeks I post the issue, I returned the product and got a replacement, after few month of use, it has been working fine. No major issues so far.
My word of advice is as soon as you identify the issue, do not try to attempt download patches here and there, and thinking you will have the issue under control, just get a swap over if you can or at least ask manufactory to look at it under warranty.
