Surface Pro 3 short battery life
2016-08-15T19:41:38+00:00
Split from this thread.
I was wondering if I have a defective unit. I have an i5 surface pro 3 and I only get about 4 hours of battery life playing YouTube videos at about 40 % brightness and about 5 hours of web browsing.  The computer shuts off when I am just below 10 % battery left. What are you guys getting?
Thank you in advance for your help.
Best regards,
Jordi
    2015-05-28T13:12:08+00:00
    My SP3 only lasts around 4.5 hours when I am browsing the internet and at around 50% brightness.
    My average CPU consumption during this activity is around 5-10%.
    Not enough activity for even the fan to be running.
    By browsing I mean, reading articles. Not even watching any videos or looking at graphic heavy sites.
    This problem has persisted since I brought the device, as you can see in the reports below
    I ran the powercfg reports and you can find them here: http://1drv.ms/1ezoXOp
    This is the my example session have the above use case:
    10:45:00 Active Battery 100 % 41,777 mWh
    11:21:18 Connected standby Battery 86 % 35,773 mWh
    11:34:08 Active Battery 85 % 35,416 mWh
    11:53:39 Connected standby Battery 77 % 32,087 mWh
    11:53:47 Active Battery 77 % 32,080 mWh
    14:01:10 Connected standby Battery 12 % 5,221 mWh
    14:02:00 Active Battery 12 % 5,191 mWh
    14:02:26 Active AC 12 % 5,092 mWh
    14:06:00 Report generated AC 14 % 6,057 mWh
    Some important points:
    • I have the i5 256gb model.
    • All updates have been installed.
    • I have tried all the basic power management techniques and I am writing this after extensive self-help
    • I try to keep my software stack lean.
    • I already contacted Microsoft chat support and that was the most useless experience ever.
    2015-02-19T14:14:35+00:00
    I purchased the S3 Pro in November and have being experiencing low battery after maybe 1.5 to 2 hours max of usage. I ran a check using the windows powercfg command to generate a report which included the following error and warnings.
    Can you help me to determine if there is something I can do to resolve this problem?
    CPU Utilisation:Processor utilisation is high
    The average processor utilisation during the trace was high. The system will consume less power when the average processor utilisation is very low. Review processor utilisation for individual processes to determine which applications and services contribute the most to total processor utilisation.
    Average Utilisation (%) 48.27
    Warnings
    USB Suspend:USB Device Rarely Entering Selective Suspend
    This device intermittently entered the USB Selective Suspend state during the trace. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
    Device Name USB Input Device
    Host Controller ID PCI\VEN_8086&DEV_9C31
    Host Controller Location PCI bus 0, device 20, function 0
    Device ID USB\VID_045E&PID_07DC
    Port Path 3
    Time Suspended (%) 16
    CPU Utilisation:Individual process with significant processor utilisation.
    This process is responsible for a significant portion of the total processor utilisation recorded during the trace.
    Process Name WmiPrvSE.exe
    PID 6168
    Average Utilisation (%) 37.95
    Module Average Module Utilisation (%)
    \Device\HarddiskVolume4\Windows\System32\kernel32.dll 17.67
    \Device\HarddiskVolume4\Windows\System32\KernelBase.dll 14.98
    \Device\HarddiskVolume4\Windows\System32\cfgmgr32.dll 3.84
    Process Name rundll32.exe
    PID 2136
    Average Utilisation (%) 0.82
    \SystemRoot\system32\ntoskrnl.exe 0.37
    \SystemRoot\system32\DRIVERS\cmdguard.sys 0.10
    \SystemRoot\System32\ntdll.dll 0.07
    Process Name chrome.exe
    PID 5996
    Average Utilisation (%) 0.49
    \Device\HarddiskVolume4\Program Files (x86)\Google\Chrome\Application\40.0.2214.111\chrome.dll 0.32
    \SystemRoot\system32\ntoskrnl.exe 0.07
    \SystemRoot\System32\win32k.sys 0.02
    PID 6668
    Average Utilisation (%) 0.44
    \Device\HarddiskVolume4\Program Files (x86)\Google\Chrome\Application\40.0.2214.111\chrome_child.dll 0.32
    \SystemRoot\system32\ntoskrnl.exe 0.04
    \Device\HarddiskVolume4\Windows\SysWOW64\ntdll.dll 0.02
    Process Name System
    PID 4
    Average Utilisation (%) 0.39
    \SystemRoot\system32\ntoskrnl.exe 0.24
    \SystemRoot\system32\hal.dll 0.03
    \SystemRoot\system32\DRIVERS\mrvlpcie8897.sys 0.02
    Process Name cavwp.exe
    PID 6008
    Average Utilisation (%) 0.38
    \Device\HarddiskVolume4\Program Files\COMODO\COMODO Internet Security\scanners\pe.cav 0.16
    \Device\HarddiskVolume4\Program Files\COMODO\COMODO Internet Security\scanners\unpack.cav 0.14
    \Device\HarddiskVolume4\Program Files\COMODO\COMODO Internet Security\scanners\script.cav 0.01
    PID 7048
    Average Utilisation (%) 0.36
    \SystemRoot\system32\ntoskrnl.exe 0.17
    \Device\HarddiskVolume4\Program Files (x86)\Google\Chrome\Application\40.0.2214.111\libglesv2.dll 0.06
    \Device\HarddiskVolume4\Program Files (x86)\Google\Chrome\Application\40.0.2214.111\chrome_child.dll 0.03
    Process Name explorer.exe
    PID 7620
    \SystemRoot\System32\win32k.sys 0.12
    \SystemRoot\system32\ntoskrnl.exe 0.12
    \Device\HarddiskVolume4\Windows\explorer.exe 0.02
    Process Name svchost.exe
    PID 540
    Average Utilisation (%) 0.24
    \SystemRoot\system32\ntoskrnl.exe 0.11
    \Device\HarddiskVolume4\Windows\System32\ntdll.dll 0.02
    \Windows\System32\wer.dll 0.02
    Process Name dwm.exe
    PID 5832
    Average Utilisation (%) 0.23
    \Device\HarddiskVolume4\Windows\System32\dwmcore.dll 0.04
    Information
    Platform Timer Resolution:Platform Timer Resolution
    The default platform timer resolution is 15.6 ms (15625000 ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
    Current Timer Resolution (100 ns units) 156251
    Power Policy:Active Power Plan
    The current power plan in use
    Plan Name OEM Balanced
    Plan GUID {381b4222-f694-41f0-9685-ff5bb260df2e}
    Power Policy:Power Plan Personality (On Battery)
    The personality of the current power plan when the system is on battery power.
    Personality Balanced
    Power Policy:Video Quality (On Battery)
    Enables Windows Media Player to optimise for quality or power savings when playing video.
    Quality Mode Balance Video Quality and Power Savings
    Power Policy:Power Plan Personality (Plugged In)
    The personality of the current power plan when the system is plugged in.
    Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
    The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
    Power Policy:Video quality (Plugged In)
    Quality Mode Optimise for Video Quality
    System Availability Requests:Analysis Success
    Analysis was successful. No energy efficiency problems were found. No information was returned.
    Battery:Battery Information
    Battery ID 291ESDIX863568
    Manufacturer SDI
    Serial Number 291E
    Chemistry LION
    Long Term 1
    Sealed 0
    Cycle Count 48
    Design Capacity 42157
    Last Full Charge 41146
    Platform Power Management Capabilities:Supported Sleep States
    Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
    S1 Sleep Supported false
    S2 Sleep Supported false
    S3 Sleep Supported false
    S4 Sleep Supported true
    Platform Power Management Capabilities:Connected Standby Support
    Connected standby allows the computer to enter a low-power mode in which it is always on and connected. If supported, connected standby is used instead of system sleep states.
    Connected Standby Supported true
    Platform Power Management Capabilities:Adaptive Display Brightness is supported.
    This computer enables Windows to automatically control the brightness of the integrated display.
    Platform Power Management Capabilities:Processor Power Management Capabilities
    Effective processor power management enables the computer to automatically balance performance and energy consumption.
    Group 0
    Index 0
    Idle State Count 11
    Idle State Type Micro Power Engine Plug-in
    Nominal Frequency (MHz) 2501
    Maximum Performance Percentage 100
    Lowest Performance Percentage 30
    Lowest Throttle Percentage 3
    Performance Controls Type ACPI Performance (P) / Throttle (T) States
    Group 0
    Index 1
    Idle State Count 11
    Group 0
    Index 2
    Idle State Count 11
    Group 0
    Index 3
    Idle State Count 11
    Device Drivers:Analysis Success
    2015-02-04T11:26:28+00:00
    Just purchased a new Corei5 126gb Surface Pro3
    The battery is draining more than I was led to expect... In ten minutes of web browsing only with no other programs in the background I have lost 10% of my battery...
    In addition with the same usage the top right corner is already exceptionally hot!
    I assume there's is something wrong.. but what? Is there a way to find out if one program is running inappropriately in the background causing both problems. Task Manager says no.
    Need answers
    Jon
    2015-01-21T17:53:48+00:00
    I experience the same when streaming videos on YouTube or using Netflix. I've never really officially timed it but it seems like it only lasts about 4 hours. I haven't tried video playback from a file locally on the device itself (without streaming). I think the majority of what I do on the Surface is web-based (streaming video or web surfing), so if using Wifi is what is draining the battery then maybe that is the source of our problems.
    Unless both of us have defective units... :-(
    2014-12-10T17:06:25+00:00
    Hi Jeff,
    I am using Chrome 40.0.2214.28 beta-m (64-bit).
    I was not using Chromecast, I was just plugged into a HDMI cable.
    Are there other things that you could see from my usage that could be a batter killer? I will definitely try IE next time and see how that impacts things.
