Thanks for responding, however the command line you suggest doesn't show the channel or signal strength: (and now the keyboard doesn't work at home either, the mouse is fine).
this is what I see at home.
SSID 1 : <my network name>
network type : infrastructure
authentication : wpa2-personal
encryption: CCMP
MY R7000 is broadcasting on the 2.4GHz and 5GHz bands, but according to the Netgear admin screen my Surface is connected on 5GHz
I left the keyboard on charge overnight, just in case it was flat,
Given the mouse and surface pen are both functional, its beginning to look like a faulty keyboard.
I'll have a go on Tuesday connecting it to my company iPhone <hawk, spit>
I responded to "BJThompson". Not sure who you are. However, first go to charms, select your network. Do that three times and see if the list changes, then run the command
netsh wlan show networks mode=BSSID
the output should look like this:
C:\Users\barb>netsh wlan show networks mode=BSSID
Interface name : Wi-Fi
There are 22 networks currently visible.
SSID 1 : digbeejune
Network type : Infrastructure
Authentication : WPA2-Personal
Encryption : CCMP
BSSID 1 : c4:04:15:29:b4:23
Signal : 82%
Radio type : 802.11ac
Channel : 157
Basic rates (Mbps) : 6 12 24
Other rates (Mbps) : 9 18 36 48 54
SSID 2 : NETGEAR77-5G
Encryption : CCMP
BSSID 1 : c4:04:15:53:cd:36
Signal : 2%
Channel : 153
SSID 3 : SepiaDove-HiSpeed
Encryption : CCMP
BSSID 1 : c8:d7:19:0d:43:95
Signal : 2%
Radio type : 802.11n
Channel : 36
SSID 4 : HOME-B34E-5
Encryption : CCMP
BSSID 1 : 60:02:92:9a:d2:e8
Signal : 16%
Channel : 40
SSID 5 : HOME-43BD-5
Encryption : CCMP
BSSID 1 : d8:97:ba:f1:3e:d0
Signal : 18%
Channel : 44
SSID 6 : five7500
Encryption : CCMP
BSSID 1 : 6c:b0:ce:26:af:40
Signal : 85%
Channel : 153
Other rates (Mbps) : 9 18 24 36 48 54
SSID 7 : HOME-1FAC
Encryption : CCMP
BSSID 1 : cc:03:fa:83:1f:ac
Signal : 38%
Channel : 1
Basic rates (Mbps) : 1 2 5.5 6 11 12 24
SSID 8 :
Encryption : CCMP
BSSID 1 : ce:03:fa:83:1f:ad
Signal : 36%
Channel : 1
BSSID 2 : c6:27:95:3f:af:5f
Signal : 36%
Channel : 1
SSID 9 : HOME-ED22
Encryption : CCMP
BSSID 1 : 58:23:8c:71:ed:22
Signal : 60%
Channel : 1
SSID 10 : xfinitywifi
Authentication : Open
Encryption : None
BSSID 1 : 5a:23:8c:71:ed:24
Signal : 60%
Channel : 1
SSID 11 : Comtrend2831
Encryption : CCMP
BSSID 1 : f8:8e:85:74:28:32
Signal : 50%
Channel : 1
Basic rates (Mbps) : 1 2 5.5 11
Other rates (Mbps) : 6 9 12 18 24 36 48 54
SSID 12 : SepiaDove
Encryption : CCMP
BSSID 1 : c8:d7:19:0d:43:93
Signal : 34%
Channel : 2
SSID 13 : football
Encryption : CCMP
BSSID 1 : c4:3d:c7:ae:40:8c
Signal : 36%
Radio type : 802.11g
Channel : 2
SSID 14 : suewireless
Encryption : CCMP
BSSID 1 : e0:91:f5:a4:ce:d8
Signal : 26%
Channel : 3
SSID 15 : deepspace9
Encryption : CCMP
BSSID 1 : 00:24:b2:14:1a:16
Signal : 38%
Channel : 6
Other rates (Mbps) : 5.5 6 9 11 12 18 24 36 48 54
SSID 16 : twofour
Encryption : CCMP
BSSID 1 : 40:16:7e:bf:0d:08
Signal : 85%
Channel : 8
SSID 17 : HP-Print-67-Officejet Pro 8610
Encryption : CCMP
BSSID 1 : a0:2b:b8:6d:5d:67
Signal : 40%
Channel : 6
Other rates (Mbps) : 1 2 5.5 6 9 11 12 18 24 36 48 54
SSID 18 :
Encryption : CCMP
BSSID 1 : 92:0d:cb:26:d0:90
Signal : 50%
Channel : 6
BSSID 2 : 02:ac:e0:f9:b9:60
Signal : 22%
Channel : 11
SSID 19 : 247500
Encryption : CCMP
BSSID 1 : 6c:b0:ce:26:af:3e
Signal : 98%
Channel : 9
SSID 20 : hawk24
Encryption : CCMP
BSSID 1 : c4:04:15:29:b4:24
Signal : 85%
Channel : 9
SSID 21 : HOME-43BD-2.4
Encryption : CCMP
BSSID 1 : d8:97:ba:f1:3e:c8
Signal : 74%
Channel : 11
SSID 22 : Gary
Encryption : CCMP
BSSID 1 : 60:02:92:99:f4:40
Signal : 68%
Channel : 11
