2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-05-10T18:51:48+00:00
    Same here. Just update with the May 9th updates, rebooted, logged in and went to do something else. Come back to my Surface, fans screaming, HOT. "LockAppHost.exe" has been running. Surface was docked all the time. Is this thing ever going to work like expected?
    After all this time, I expect it to fail all the time. My Surface never fails to meet these expectations :)
    2016-05-10T06:37:47+00:00
    2016-04-30T13:13:14+00:00
    last week, I just reset my SP4 with fresh recovery image,and then patch to all 4/19 updates.
    but I still have the battery drain issue. I check it's LockAppHost which costs the most battery energy.
    who can tell me the workaround?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=a06419a1-9374-40b7-88f2-a1849b0bec30)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3d9839f2-e342-449a-b2b1-bb7dca7205a4)
    2016-04-29T20:49:37+00:00
    Today my Surface Pro 4 can't properly sleep again. When I remove it from my bag, it is really hot!
    The sleep study shows that it can't enter connected standby.
    Top Offenders
    Top 5 offenders, ranked by active time
    NoCsPhase.Invalid PDC Phase 100% 0:55:40
    CPU C0 Time Processor 90% 0:49:47
    CPU C0 Time.Non-attributed Time Processor 88% 0:48:47
    Marvell AVASTAR Wireless-AC Network Controller Networking 9% 0:04:50
    BI Activator 4% 0:02:13
    No CS Phase 100.2% 0:55:40
    Connection Phase 0.0% 0:00:00
    Shell Phase 0.0% 0:00:00
    PLM Phase 0.0% 0:00:00
    Maintenance Phase 0.0% 0:00:00
    DAM Phase 0.0% 0:00:00
    Low Power Phase 0.2% 0:00:05
    Resiliency Notification Phase 0.0% 0:00:00
    Resiliency Phase n/a n/a
    Power consumption (look at the Total consumption, incredible! )
    \Device\HarddiskVolume3\Windows\System32\LockAppHost.exe [username] 30713495 18676911 0 0 0 0 0 12036584
    System [SYSTEM] 181341 102791 0 0 0 9889 0 68661
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [LocalSystemNetworkRestricted] [SYSTEM] 180876 113784 0 0 0 0 0 67092
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [netsvcs] [SYSTEM] 109534 60474 0 0 0 6103 0 42957
    System Interrupts [SYSTEM] 95272 54453 0 0 0 0 3778 37041
    \Device\HarddiskVolume3\Windows\System32\RuntimeBroker.exe [username] 40604 24258 0 0 0 0 0 16346
    \Device\HarddiskVolume3\Windows\explorer.exe [username] 14669 8515 0 0 0 724 0 5430
    \Device\HarddiskVolume3\Program Files\ESET\ESET Smart Security\ekrn.exe [SYSTEM] 12473 6024 0 0 0 1687 0 4762
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [RPCSS] [NETWORK SERVICE] 11419 6911 0 0 0 0 0 4508
    Microsoft.Windows.Cortana_1.6.1.52_neutral_neutral_cw5n1h2txyewy [username] 9891 3177 0 0 0 2692 0 4022
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [DcomLaunch] [SYSTEM] 7929 4882 0 0 0 0 0 3047
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [NetworkService] [NETWORK SERVICE] 6868 2901 0 0 0 1337 0 2630
    Microsoft.WindowsStore_2016.29.13.0_x64__8wekyb3d8bbwe [username] 4927 2678 0 0 0 273 0 1976
    \Device\HarddiskVolume3\Windows\servicing\TrustedInstaller.exe [SYSTEM] 4847 2941 0 0 0 0 0 1906
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [LocalServiceNetworkRestricted] [LOCAL SERVICE] 4813 3003 0 0 0 0 0 1810
    \Device\HarddiskVolume3\Windows\System32\svchost.exe [appmodel] [SYSTEM] 3801 2280 0 0 0 0 0 1521
    \Device\HarddiskVolume3\Windows\System32\lsass.exe [SYSTEM] 3699 2254 0 0 0 0 0 1445
    I am really angry that now it is 6 months after the launch of Surface Pro 4, and we still could not get a computer that can sleep whenever it should sleep!
    This is definitely the worst PC I have ever owned!
    All firmware and drivers are the newest.
