My Surface Pro 4 M3 version always had the issue where if I put it onto a sleep mode, it would run extremely hot and battery will drain. In other words, it never falls asleep (along with the screen not turning on after putting onto a sleep, really annoying
takes like 2 minutes and 10 different power button pushes to turn on a screen).
I just did the latest update (Apr 18 2016 or something like that) but the issue still persists. This time it scared the **** out of me because I put it onto sleep mode yesterday night after fully charged, put it into a sleeve, woke up after 8 hours, and
the sleeve was extremely burning hot so I took it out and the battery was about 20~25% or so.
This is a serious issue guys. Are you guys gonna act later when it seriously burns someone's house or a room? You guys can expect some serious massive lawsuit if you guys don't do something about this.
The machine seriously needs a critical follow-up update, a recall, or a free upgrade to Surface Pro 5 or something. This is so concerning.
