2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-15T16:40:00+00:00
    No, my device does not go into DRIPS, if that is what you mean by low power state. I can post screenshots if that helps.
    2015-11-15T13:49:40+00:00
    My SP4 has the same issue. It shows 0% for low power state, and both the CPU and graphics consume high power in connected standby.
    2015-11-15T13:29:07+00:00
    Can your device go into low power state?
    Could you share your sleepstudy report, either?
    2015-11-15T10:46:53+00:00
    Just to follow, this is my connected standby session from last night, the two hours before it slips into hibernate  (essential due to me having an additional issue where the SP4 won't wake if left for many hours in CS).
