2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-19T20:40:24+00:00
    I'm not sure what you mean by stand-by.  But this made me wonder. When the unit is in sleep mode, should I have it set so that wi-fi is OFF DURING SLEEP?  I have never done that with a laptop, but maybe that would keep it from getting warm?
    Hibernate is slower to wake up, I wonder I turning wi-fi back on after waking from sleep makes the time difference a wash.
    I use sleep with WiFi off during sleep, and when I wake up the device the WiFi connects in less than two seconds.  That's not a wash versus the time for hibernate for me.
    2016-02-19T20:30:31+00:00
    The sleep battery drains/heating seems to be addressed after update. But it seems that there is another heating/drains issue when wifi stand-by is turned on.
    Battery life is fine when sleep with wifi stand-by off but Surface drains quickly and get heating up with standby on, no matter plug in or not.
    2016-02-19T19:56:55+00:00
    2016-02-19T15:57:27+00:00
    I have a applied this update to two of my Surface Pro 4 machines and both of them blue screened, restarted told me I needed to recover the OS.....  It then came back on its own.  I then had issues with my wifi nic again.......
