2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-18T17:21:39+00:00
    About 8 AM, it said 98% charged. When unplugged it displayed 5 hours and 38 minutes. When I put it in the briefcase and opened it in the office, it was hot, The battery had drained 50% and displayed something like 2 hours +. When I closed it and put it on my desk, it had cooled down.
    In the sleep study, it shows, I had only 5% change. However, the change rate is 1408 mW. Can somebody explain? Thanks.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=10025113-2e70-44e3-98ff-a191a140d533)
    2016-02-18T16:54:15+00:00
    Thank you.
    2016-02-18T16:32:05+00:00
    Run cmd.exe as an administrator then type powercfg sleepstudy
    2016-02-18T16:19:57+00:00
    Further update, put it to sleep for one hour and the drain rate was 139mW. Completely fixed.
    Edit:
    How do you run this test? After the update my sp4 battery decreased from 84% to 73% in 22min and the FAN came on due to Heat. I would appreciate your help to know how to diagnose whats causing the drain?
