2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-14T21:51:07+00:00
    The same issue on my SP4 (i5/8/256), it seems that surface just turns off the display and all other parts are working as they are in use: CPU and HD520 chewing the power.(Windwos hello disabled, Hyper-V disabled, WiFi-standby disabled).
    This issue exists even after TH2 10586build update. Do you have any solution for this now?
    I got to know there might be something stopped the surface to turn into sleep. But I do not know how to find out and disable it.
    2015-11-14T16:19:16+00:00
    Same here. After the November update, I'm seeing SB.PCI0.GFX0 consuming more power during sleep. I wish I knew why :(
    2015-11-14T09:44:18+00:00
    update:after the 18,Nov firmware update, although the battery driver is renewed, this issue still exists.
    After the update of threshold 2, my first Surface pro 4 (i5, 256G, 8G) has a battery drain issue during sleep even though the battery saver and airplane mode  are on.
    I ran the "powercfg /sleepstudy" to get the report, and it showed the system had heavy activities, and there was no "low power period" (the device never went into "deep sleep"). And the charge rate is more than 1000 mW, which means it will drain out all the power in 24 hours sleep.
    It sleeps normally before the Threshold 2 update.
    I went to the Microsoft store and replaced my device twice. However, without installing any third-party software and personal data, Windows Hello disabled, airplane mode and battery saver mode are turned on, these two new devices have the same issue especially after the threshold 2 update.
    It seems the GPU and CPU are active Around 15% of any sleeping session , and the Soc is stuck in resilience phase, can't go into low-power state (DRIPS) totally.
    P.S.: Another annoying issue is that whenever the charger is plugged in or out, the device wakes up even though the type cover is closed. I just wanna charge it or leave home, I don't expect to use it since the type cover is still closed.
    According to the MSDN file below. A common reason for a connected standby session to have zero percent software and hardware DRIPS is that a critical driver is not loaded on the system.
    Connected standby SleepStudy common problem examples
    https://msdn.microsoft.com/en-us/library/windows/hardware/dn495348(v=vs.85).aspx
    Below is the  Sleepstudy report. Hope you will fix this issue quickly. Get a full version from the shared link.
    https://onedrive.live.com/redir?resid=CC3EAA2B7BEA4488%217143
    pdf version:
    https://onedrive.live.com/redir?resid=CC3EAA2B7BEA4488%217144
    2015-11-05T13:55:42+00:00
    completely missed that.  Perhaps if he sets it up and then dos back the remove button will appear.  Just a thought.
