Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-10-22T05:33:38+00:00
    In my case it is drain from 100% to 0% in 9 hours in complete shutdown.
    Microsoft agree to make a a replacment hope this refurbish unit will not do any problem again.
    2018-10-22T02:25:56+00:00
    It gets worse.  What happened to me is that it reaches a point where the unit will not turn on even when under charging.  I have to leave the unit on charge overnight to get it to the point where it will turn on again.  The problem is a basic design flaw which MS will NOT accept responsibility for!.  Unlike many other computers, the battery CAN NOT be swapped out from a new one by the consumer.  What MS is doing s called aggressive planned obsolescence!  They want disposable computers sold that have to be replaced every 1 to 2 years grabbing a thousand bucks or more out of everybody.  That's their business model they have created.   They will never fix this problem.  They wanted it by design.   I won't buy another computer from MS.  And I am pursuing a class action lawsuit as a solution.   They will not listen voluntarily.
    2018-10-22T01:01:16+00:00
    i think battery that drains about 4-5% in 24 hours is normal. mine was draining just like yours when i got my refurbished unit. then in about 2 months, it starts to drain more and more. now in 24 hours about 15%++. called the MS customer service but they told me it was normal to degrade.
    checked in this forum, maybe because it still active even when i did complete shutdown because of its auto wifi searching, update etc. i did turn it off this time but it still drains. last 100% charged was last friday 12 afternoon, start the SP4 this monday morning, the battery was 0%. completely drained. sigh!
    anyone else got the same prob as me? any other options that i can use?
