Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2017-10-16T15:33:27+00:00
    I've also done a clean wipe of the device and tried the things suggested online and on this thread. But nothing was able to fix the issue. I feel how you feel.
    The only option left is to trade it in Microsoft for a device in "mint" condition. This options means going through all the hassle of going to the country I bought the device just to get it replaced, and the replacement won't be a brand new device. Microsoft support also cannot guarantee that the replaced device will be free from issues. Totally not worth it! Looks like I have to live with it. Really disappointed after paying so much. Feel so powerless.
    2017-10-16T15:16:59+00:00
    Same issue here!
    I wiped my Surface Pro 4 and flashed it with a recovery image from https://support.microsoft.com/en-gb/surfacerecoveryimage - didn't change anything.
    With the new image I tried many things including the shutdown.exe with no effect (windows reports an uptime of a few second after start, so it was really off). When it touch the Surface after being off for about 20 hours, it seems a little bit warm (not hot).
    Also installed the latest firmware, i.e. all available updates as of Oct 16 are installed.
    It's not a battery issue, because when the Surface is on, the battery life is quite normal.
    This is really annoying! My battery got drained to 0% several times and I'm sure this already ruined the battery to some extent. For an expensive device like this, it's really a shame to see how many customers get their devices bricked by firmware updates :(
    2017-09-30T01:16:03+00:00
    Modern Standby is active when the display is off but the system is not in hibernation or powered down.
    If your system is draining power while being powered down, I would suspect the battery is not holding power or some internal component is leaking in some manner.
    But again, I do not have a Surface and may not understand the two battery situation.
