Crap. My SP3 now shows battery is not detected. I have tried to reimage, disable the battery, manually apply the firmware, power reset. Nothing. it is now a brick without ac adapter. Not very mobile..
Surface Pro 3 LGC Battery Degradation
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
2016-12-20T22:45:35+00:00 -
2016-12-20T15:27:41+00:00 Here is the best "Do Not Buy for Christmas List" I have found this season: https://www.microsoft.com/en-us/
2016-12-20T15:03:05+00:00 There is only 2 possibilities. Either Microsoft is not smart enough, or they do not care.
I personally believe they do not care.
I walked through the local Best Buy, and totally ignore Surface Pro 4's or any other Microsoft hardware now. I will not use in my business or recommend to my clients.
Microsoft has made me look like a fool for the last time.
2016-12-20T14:55:46+00:00 Lost cause. Millions are just out cash and up one doorstop tablet.
2016-12-20T14:39:08+00:00 I think a class action lawsuit is our only option.
