Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
    2016-11-09T01:59:47+00:00
    My firmware update won't finish.  Surface pro embedded controller remains a splat, says a restart is required to get it to finish but when I restart nothing changes, it never succeeds.
    What can I do to finish the update?
    2016-11-09T01:35:07+00:00
    Hi Greg,
               Same here, I had to send my surface pro when the August patch didn't work :( Will there be a refund? I had to pay $500 which is not a small amount and doesn't feel like worth to spend when it's a firmware issue.
    Avinash K N
    Hello everyone,
    We are aware of a battery issue that is affecting a limited number of Surface Pro 3 users. We can confirm that the issue affecting these customers was not caused by the software updates issued on August 29th. Our team is actively looking in to the issue to determine the cause and identify a fix. We will post an update as soon as we have more information to share.
    Greg
    Hello everyone,
    Thanks for your patience while we identified a fix for this issue. We have now completed our testing of an update and it has passed our quality assurance process.
    The update, “System Firmware Update - 11/7/2016”, is now available to install from Windows Update.
    Should you need any further assistance, please contact us
    Thanks again.
    Greg
    Good luck. I paid out of pocket as one of the earliest to report the Simplo battery issue. There was a promise people like me would be contacted. No reports of anyone being refunded 3 months later...
    2016-11-09T01:28:46+00:00
    Well I'm leaving my SP3 on overnight to download the update. Last time I did this it killed the Surface completely so wish me luck.
    Which reminds me Microsoft, now that you've admitted it is a firmware issue are you going to replace my first SP3 that you killed in August or am I going to have to get legal support to make you?
    2016-11-09T01:09:26+00:00
    Can I reapply the firmware update?
    2016-11-09T01:08:43+00:00
    Unfortunately for me ... I was not so lucky.
    My SP3 was in the dock and updated before I found out about this.
    NOW WHAT DO I DO?
