Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
    2016-09-22T22:05:12+00:00
    Greg, Thanks for Recognizing the issue. It makes me feel a little better knowing that there may be a fix being worked on.
    I have the LGC battery and had also used it that day portably on battery. That evening I received a firmware update (it looked different than the usual windows update). The next day I noticed the issue begin to manifest. (plugged in no charge, and dies when unplugged) I did a windows update to try and repair the issue and got the anniversary update.  It made no difference the problem was still there.  Also tried to uninstall the battery driver as some sites suggested, with no luck.  Reset my SP3 to factory, and still having issue.
    Battery report
    COMPUTER NAME DESKTOP-4A1ORTU
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 14393.187.amd64fre.rs1_release_inmarket.160906-1818
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-09-22 00:16:52
    Installed batteries
    Information about each currently installed battery
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1211376388
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 34,656 mWh
    CYCLE COUNT 60
    Recent usage
    Power states over the last 3 days
    2016-09-21 15:30:52 Active AC 65 % 22,678 mWh
    15:36:00 Suspended 65 % 22,678 mWh
    15:36:37 Active AC 65 % 22,678 mWh
    15:49:49 Connected standby AC 65 % 22,671 mWh
    15:49:53 Suspended 65 % 22,671 mWh
    20:21:01 Active AC 65 % 22,618 mWh
    20:22:40 Battery changed AC - -
    20:22:40 Connected standby AC - -
    20:22:41 Suspended - -
    20:23:57 Battery changed AC 65 % 22,618 mWh
    20:23:57 Active AC 65 % 22,618 mWh
    20:25:00 Battery changed AC - -
    20:25:00 Active AC - -
    21:05:00 Battery changed AC 65 % 22,618 mWh
    21:05:00 Suspended 65 % 22,618 mWh
    23:16:26 Active AC 65 % 22,587 mWh
    23:31:18 Connected standby AC 65 % 22,587 mWh
    23:31:19 Suspended 65 % 22,587 mWh
    23:31:56 Connected standby AC 65 % 22,587 mWh
    23:31:56 Suspended 65 % 22,587 mWh
    23:45:03 Active AC 65 % 22,580 mWh
    23:45:03 Suspended 65 % 22,580 mWh
    23:49:35 Active AC 65 % 22,580 mWh
    23:49:35 Suspended 65 % 22,580 mWh
    23:50:23 Active AC 65 % 22,572 mWh
    2016-09-22 00:09:36 Suspended 65 % 22,572 mWh
    00:10:14 Active AC 65 % 22,572 mWh
    00:16:00 Report generated AC 65 % 22,572 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    Battery capacity history
    Charge capacity history of the system's batteries
    Battery life estimates
    Battery life estimates based on observed drains
    Current estimate of battery life based on all observed drains since OS install
    Since OS install - - - -
    2016-09-22T20:32:36+00:00
    My odds calculator does not go that high. I just hope they find a solution before it goes to much longer
    2016-09-22T19:39:13+00:00
    I am not understanding ms stance that the update did not cause the issues we are having. Thousands of people did the updates and now have the problem.
    2016-09-22T19:34:58+00:00
    Not everyone
    I have been reporting this problem since febuary
    2016-09-22T19:34:13+00:00
    My LG battery is also showing up signs of degradation after only 30 cycles after the update. The battery wear level is 96.7% which is unacceptable for this very low count. I got my Surface Pro 3 replaced a few months ago with a new one due to heating issues and have not used it much since. Here is the battery report generated today:
    Battery report
    COMPUTER NAME DESKTOP-3AKI8FP
    PLATFORM ROLE Slate
    REPORT TIME 2016-09-2300:44:53
    Installed batteries
    NAME X883815
    SERIAL NUMBER 1199448068
    CHEMISTRY LION
    FULL CHARGE CAPACITY 40,766 mWh
    CYCLE COUNT 30
    Recent usage
    2016-09-2001:16:56 Active AC 20 % 8,254 mWh
    01:59:19 Suspended 38 % 15,291 mWh
    2016-09-2223:31:36 Active Battery 41 % 16,667 mWh
    23:43:24 Active AC 32 % 13,064 mWh
    23:45:41 Active Battery 32 % 13,232 mWh
    23:45:51 Active AC 32 % 13,209 mWh
    23:56:38 Active Battery 38 % 15,382 mWh
    23:56:43 Active AC 38 % 15,390 mWh
    2016-09-2300:40:26 Suspended 58 % 23,446 mWh
    00:40:53 Active AC 58 % 23,507 mWh
    00:42:44 Active Battery 58 % 23,742 mWh
    00:43:02 Active AC 58 % 23,704 mWh
    00:43:02 Report generated AC 58 % 23,704 mWh
    Battery usage
    2016-09-2223:31:36 Active 0:11:48 9 % 3,603 mWh
    23:45:41 Active 0:00:09 - 23 mWh
    23:56:38 Active 0:00:05 - -8 mWh
    00:42:44 Active 0:00:18 - 38 mWh
    Usage history
    2016-09-07 - 2016-09-14 1:37:39 0:00:10 0:06:23 -
    2016-09-15 - - - -
    2016-09-16 - - - -
    2016-09-17 - - - -
    2016-09-18 - - - -
    2016-09-19 - - - -
    2016-09-20 0:43:54 - 0:42:22 -
    2016-09-21 - - - -
    2016-09-22 0:12:02 - 0:16:20 -
    2016-09-07 - 2016-09-14 40,766 mWh 42,157 mWh
    2016-09-15 40,766 mWh 42,157 mWh
    2016-09-16 40,766 mWh 42,157 mWh
    2016-09-17 40,766 mWh 42,157 mWh
    2016-09-18 40,766 mWh 42,157 mWh
    2016-09-19 40,766 mWh 42,157 mWh
    2016-09-20 40,766 mWh 42,157 mWh
    2016-09-21 40,766 mWh 42,157 mWh
    2016-09-22 40,766 mWh 42,157 mWh
    2016-09-07 - 2016-09-14 3:53:18 7:32:57<br><br>212 % / 16 h 4:01:16 7:48:24<br><br>205 % / 16 h
    2016-09-15 - - - -
    2016-09-16 - - - -
    2016-09-17 - - - -
    2016-09-18 - - - -
    2016-09-19 - - - -
    2016-09-20 2:35:38 - 2:40:57 -
    2016-09-21 - - - -
    2016-09-22 2:15:35 - 2:20:12 -
    Since OS install 3:14:34 7:32:57<br><br>212 % / 16 h 3:21:12 7:48:24<br><br>205 % / 16 h
