Thanks Adam. Unfortunately, this did not work for me. On Friday I applied the updates from https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
and today was greeted with the error about not being able to start the camera while trying to wake the PC to log in. FWIW, I'm on a Surface Pro 8 using the Windows 11 22H2 and Intel Xe Graphics.
Surface Pro 8 Camera Not Working - yet white light remains on?
Split from this thread.
I too have a similar problem with the camera and Surface Pro 8. I use Windows Hello to log in and after the device has been left for some time the device will unlock but if you then try to use video in a Teams call the screen will be blank and it will report that no camera is present. I have run Windows update, Updated the camera drivers, and run the surface app to check the firmware is up to date. run the Surface hardware diagnostic tool. None of these found any problem.
I have updated the Teams Client, and tested with both the desktop and web client. when having the issues and the problem it present on both.
I full reboot will get the camera working but that is not possible when in the middle of a call.
The only way to fix it without rebooting is to open the device manager and disable and then enable the camera. This will normally fix the video in Teams.
We are a small company but we all run Surface Pro 8's managed by Autopilot/Intune with very little in the way of additional software. All are less than 12 months old. More than 50% of the staff are having issues with video calls within Teams after a period of inactivity.
Surface | Surface Pro | Sound and camera
2023-12-18T16:32:08+00:00 -
2023-12-15T08:34:48+00:00 Try updating the graphics drivers manually .. it seems like that fixed it on my Surface 8, finally. https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
These gfx drivers (Intel Xe on my system) apparently arn't always pushed to latest Intel version via windows update b/c it appears the surface team does QA on them before pushing them out.. (this is a good thing generally.. )
but it seems like as a result of that process things that fix bugs like this sometimes lag a little. Hopefully this works for others.
Thank you so much Adam for this solution! It seems to have worked for me too!
2023-12-14T22:27:09+00:00 Thanks, Adam.
I think the firmware for Pro 8 fixed the issue. I tried to install graphic card driver to the 7 and 7+ versions, however wasn't suitable for those models. Luckily, they just released the firmware for 7+ and installed them on a few PCs. Let's see how they go. However, still nothing for 7 models. I guess, they are doing it one by one.
We are glad they are working on the issue even though took me longer than 6 months to get this fixed.
@David agreed. Totally disappointing that Microsoft device breaks down in Microsoft Teams calls.
2023-11-29T00:02:34+00:00 I have tried that too but haven't heard from users back, yet.
And Surface Pro 7 and 7+ got the issue as well. Haven't seen anything about them, yet.
2023-11-28T23:53:36+00:00 To be fair to the surface team, it does appear that they pushed out an update to the camera firmware (at least for my Surface Pro 8), per https://support.microsoft.com/en-us/surface/surface-pro-8-update-history-1080bf34-7e87-408c-8619-80571283526e . Sadly this didn't fix the issue for me.
So it's not like they're not trying at least... Hardware and drivers are hard.
