Microsoft Surface Pro 4 Crackling Sound
2017-11-30T02:39:01+00:00
I've had my MS Pro 4 for a few days now. Updates are installed and it's working fine. I hear a crackling or arcing sound every once in a while. It even happens when in sleep mode. Should I be concerned or is there an explanation for this?
Surface | Surface Pro | Sound and camera
    2018-04-21T05:00:57+00:00
    okay ive been one my google journey and really need an answer I sent the screen to get replaced and reset the whole thing and its static popping noise continues in random intervals in the middle of the night, I have so many mental issues that cause anxiety attacks I don't need another, I got mircosoft bc apple is outdated and stole software hence macintosh, but that's besides the point my warranty is almost up and I need an answer soon or I will smash my screen and get a stupid MacBook as long as it behaves adeQUIETLy
    2018-04-20T17:20:59+00:00
    We have the same problem. This should be easily reproducible by Microsoft at this point.
    2018-04-19T21:06:40+00:00
    It is a surface pro 4
    2018-04-19T14:20:06+00:00
    Surface Pro 4
    2018-04-19T08:28:28+00:00
    To be clear, Do you mean a "Surface Pro" or a "Surface Pro 4"
