Microsoft Surface Pro 4 Crackling Sound
2017-11-30T02:39:01+00:00
I've had my MS Pro 4 for a few days now. Updates are installed and it's working fine. I hear a crackling or arcing sound every once in a while. It even happens when in sleep mode. Should I be concerned or is there an explanation for this?
Surface | Surface Pro | Sound and camera
    2018-04-19T00:07:12+00:00
    I purchased this Surface PRo 5 months ago through QVC.
    The crackling sound happens both when it is plugged or unplugged and when it is sleep mode.
    I have not tried to fix it.  That is why I am writing to you .
    2018-04-13T13:35:31+00:00
    The guy at the Microsoft store was so nice. I explained the problem and my frustration. He replaced my sp4 on the spot with the newest version (still no answer to the cause of the noise though).
    2018-04-12T14:04:22+00:00
    I live in Belgium... no Microsoft stores here. My device is my 6th or 7th replacement (lost count) and is now out of warranty...
    2018-04-12T13:58:57+00:00
    In this case, it would be best that you visit our nearest Microsoft Store to have them check your device. You may also contact our Global Customer Support for recommendations.
    Regards.
    2018-04-06T01:04:32+00:00
    Yes I have the same problem which I cannot seem to find a solution. Anyone have one?
