I am not the OP, but I have the same problem (if in fact it is a problem). I hear the crackling sound after I close and set down my Surface. Doesn't matter whether the power supply is plugged in or not. I haven't tried any troubleshooting, since I don't know if this sound is a problem. Is it?
Microsoft Surface Pro 4 Crackling Sound
I've had my MS Pro 4 for a few days now. Updates are installed and it's working fine. I hear a crackling or arcing sound every once in a while. It even happens when in sleep mode. Should I be concerned or is there an explanation for this?
Surface | Surface Pro | Sound and camera
2017-12-28T17:04:49+00:00 -
2018-02-23T00:59:45+00:00 I have the same issue as well. After fall creators update, speakers pop while in sleep mode. Event manager shows the same warning as posted. This is not an isolated incident. Google this and you'll find plenty of people with SP4 complaining about speaker pops while the surface is on standby. Reinstalling drivers did not fix the problem.
Microsoft, what are you doing about this?
2018-02-27T15:57:25+00:00 I wonder if there is a way for Microsoft to link all of the different people having this problem (I'm one of them) so we can share what we have tried. This is really annoying! I have been working with a support agent (who has been very patient with me) for over two weeks on this issue. We have run all of the diagnostics, uninstalled most of my games, automatically and manually updated drivers, disabled a number of audio features, and the crackle remains. My most recent test has been to put the volume at zero before putting the unit to sleep; I have not notice a crackle since I did this, but I've been sick and not near the Surface, so I cannot confirm that it is actually working.
A few links I found - again, I hope Microsoft can link these together and get the problem solved!
http://www.surfaceforums.net/threads/sp4-audio-crackling.18666/
I'm sure there are other posts out there. If I get a chance, I'll try to summarize what problems people are having, and what solutions have been attempted. Although, I'm pretty sure that is what the Microsoft employees are paid to do...
2018-02-07T20:51:20+00:00 Hi,
There might be certain apps/programs that cause the crackling sound. Were you able to determine the area where the noise comes from? Also, you might want to run the Surface Diagnostic Toolkit, see if it helps. The diagnosis may take 15 minutes or less, but can take an hour or longer and depending on your internet connection speed and the repairs that the tool needs to do to fix the problems.
Click here to run the Surface Diagnostic Toolkit.
If you're in the US, we recommend that you go to the nearest physical retail Microsoft Store and have your Surface device checked by our technician. It's the best way we can hear the crack/pop sound, and ensure that the replacement unit doesn't have the same issue. You might still be under the 90 day refurb replacement warranty so you might want to consider getting another replacement. You can also contact our Global Support for assistance.
Let us know if you have any other concerns.
Regards.
2017-12-29T00:46:32+00:00 Hi,
Let's try this. To check if it is software-related issues, you can run the Surface Diagnostic Toolkit.
Let us know how it goes.
Regards
