With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
Double tap to left click and drag on trackpad
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
Greetings all,
The “Tap, then tap and slide one finger in any direction" gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
2013-11-06T22:35:01+00:00 I have all the updates installed with the cover connected. I have only tested it on the Surface Pro which is what I have.
2013-11-06T21:06:30+00:00 Hello,
Sorry to hear about the issues with the Type Cover 2.
To clarify, have you installed all Windows Updates with the Type Cover 2 connected? Is the issue on Surface Pro only?
Please let us know.
Best regards.
2013-11-04T03:48:30+00:00 I have the same problem with the black type cover 2 keyboard cover. I am considering returning the keyboard as defective, but I don't want to exchange it if it is a driver problem. Is there a fix underway or do I need to return this.
Issue: Cannot hold the left click button while selecting text. Instead, it acts as if the left click button was released before I am able to select the entire text desired.. It is most noticeable in Microsoft Word.
