Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-04-11T16:31:35+00:00
    Sorry for the maybe stupid advice, but it happened to me that I did not get the full update on first trial.
    Best RS2
    Same thing happened to me.  Didn't start working until the update I got on 4-11, "Windows 8.1 Update for x64-based systems (KB2919355)"
    Good luck!
    2014-04-10T21:34:32+00:00
    Are you sure to have the update completed?
    To check, have a look at the start screen and whether there is a search symbol (magnifying glass) next to your avatar and login name.
    Best RS2
    2014-04-10T20:57:30+00:00
    I just noticed this too.  This update is definitely a welcomed improvement!
