Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-04-09T00:39:39+00:00
    Great suggestion!  I have been using AutoHotkey for years, and looking for a solution to the double-tap and drag problem - never thought about this being a fix.  Still hoping for a fix, but this will work in the meantime.
    2014-03-28T05:12:33+00:00
    Greetings all,
    WHY is tap, then tap and slide NOT supported????  This is an almost universal windows touchpad gesture.  I don't find this good MS support to just say it's not supported.
    Come on MS...FIX this issue and support your Surface customers who have supported you and purchased your hardware!!!
    This is fixed in the Update 1 coming in the next couple weeks.
    2014-03-28T04:46:42+00:00
    Greetings all,
