Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-02-10T16:10:27+00:00
    Thanks for this workaround. Works better than I thought it would!
    2014-02-10T08:41:57+00:00
    thinking of doing the same.  The trackpad small, jumpy, and now this.
    I have the Type Cover 1 and it has this feature. I hate it. I've never used the tap and drag and when I hover over things with the cursor, I move them accidentally! This happens every time and I finally had to buy a bluetooth mouse, along with the pad and the pen.
    Does anyone know how to deactivate this function so it works like in the Type Cover 2?
    2014-02-09T21:27:33+00:00
