Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-01-16T13:55:30+00:00
    Yes you're right but the buttons on the touchpad are terrible and it's such a cramped space to work in. I personally think holding a key and using the entire track pad for navigation is far easier.  At least until a fix comes out.
    2014-01-16T13:48:17+00:00
    Isn't this the same as holding down the left click button below the trackpad with another finger?
    2014-01-16T12:06:42+00:00
    That is a brilliant idea and I'm going to try it! Thanks!
