With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
Double tap to left click and drag on trackpad
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
Greetings all,
The “Tap, then tap and slide one finger in any direction" gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
2013-12-11T06:06:58+00:00 The original poster edited his answer to say that according to customer support, "a fix is planned".
Your answer here seems to indicate that the "fix" is to update the documentation to say that this is not supported.
I really hope you actually fix this issue to allow the "double tap and slide" gesture - I for one find the requirement to hold the left touch button down quite inconvenient, especially on a smallish touchpad such as with the type cover 2.
2013-12-11T03:30:09+00:00 Are you talking about the Touch or Type cover? I have no problems with the keys on the Type cover, just the trackpad.
I talk about the Type cover, and the trackpad, not the keys. The track pad Do Not manage double-click !
2013-12-11T00:37:18+00:00 Are you talking about the Touch or Type cover? I have no problems with the keys on the Type cover, just the trackpad.
