With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
Double tap to left click and drag on trackpad
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
Greetings all,
The “Tap, then tap and slide one finger in any direction" gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
2013-11-21T10:59:38+00:00 It actually doesn't work on my Touch Cover 2 (nor does the finger rolling thing).
Considering this is fixable at the software level, I think it's reasonable to expect that feature from a $100+ keyboard.
Interesting because I spent a bit of time at the Microsoft store testing it and showing their people the problem. I wonder if they had a touch cover 1 out even when they said it was the 2.
Anything is possible I guess, but I was pretty sure it was the 2 because of the slight differences. I will go back mad check again.
In any case, it should be simple for them to fix.
2013-11-21T09:31:07+00:00 I would not have bought Type Cover 2 if this was known before. The documentation clearly stated that it supports this gesture. All my laptop touchpad's over the last 10 years have supported this.
I would have gone for a less expensive blue tooth keyboard or perhaps no surface 2.
Quite frankly, the Type Cover 2 is faulty and contravenes our consumer rights by not supporting the advertised feature.
Microsoft need to:
A: fix the problem
B: Recall all Type Cover 2 keyboards and refund or replace
Consumers have rights you know!!!
2013-11-21T04:28:42+00:00 It actually doesn't work on my Touch Cover 2 (nor does the finger rolling thing).
