http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
Select windows 8
reboot.
Works better than any of the previous Wacom Penabled Windows Tablet PCs I've used since 2002! http://pocketnow.com/2013/05/13/surface-pro-digital-artists-dream Love it!
Works great!
I have the following questions :
1. Will this [work] on all drawing / canvasing applications even like in "Paint" ?
2. Do I have to use a different / compatible stylus for this?
Please suggest.
VN
Hello VN_Surface! I will try to answer as clearly as possible >.< (I know I'll end up writing a messed up paragraph per question… sorry ._.)
Select windows 8
reboot.
Hi All,
I have downloaded and installed the drivers. Thanks to MS and Wacom.
1. Will this on all drawing / canvasing applications even like in "Paint" ?
Please suggest.
VN
