Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
    2013-05-10T09:36:27+00:00
    Just in case someone at Wacom gets the terrible idea of pulling the driver out of their website, I have mirrored the file and it is available from there:
    http://www.surfaceproblog.com/pen-pressure-sensitivity-finally-works-in-adobe-photoshop/
    2013-05-10T07:56:56+00:00
    Hey Youvi :)
    would be nice if you could upload a short clip in which you are skulpting in Zbursh! :D would be awesome to see!
    2013-05-10T04:46:03+00:00
    Just tested now...
    Download is working fine...
    Thanks Wacom and Microsoft ... you save my day ^^
    edit:  working on Photoshop and Zbrush now ... pressure is working fine ^^
    2013-05-10T04:08:41+00:00
    the router was reset. but this also happens on a tmobile 4g tethering connection, taking my ISP out of the equation. i am going to try downloading it with my iphone.
