http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
Select windows 8
reboot.
Hugo & the other support folks are not responding to requests in other threads for a beta driver to fix the non working stylus with Adobe and other products. Even an unsigned driver would be acceptable. Microsoft promised a driver "soon" over a month ago on Twitter. Latest info is vague and non informative but states the team is testing a driver.
If there is a driver, then it should be made available to the community for testing and for feedback.
The silence from Microsoft on this request is disturbing. Other companies regularly release beta drivers to the enthusiast community.
Either there is a driver in testing or this is all smoke and mirrors.
Is there anything that lets you draw in vector? I am wanting pressure sensitivity in Illustrator.
Let's not downplay Sketchbook. Its a great program from Autodesk that does its job extremely well for several years now.
Sketchbook's support of the Ink API is less than ideal - as a temporary stop gap I had to go with ArtRage instead. Sketchbook doesn't support touch pan and zoom without WinTab, and there is a multi-second delay after using the eyedropper tool (a killer for digital painting).
