This is unbelievable. I can't do my job with this device now. Is anyone thinking of a class action?
Surface Pro 7 Slow WiFi
Hello everyone,
I am working with my new Surface Pro 7 i5 one or two days now and unfortunately, I still have severe wifi issues after installing all updates. Speed is between 0 and 1,250 kbit/s.
After searching for this issue, I found several entries describing this kind of problem and some workarounds like setting the MIMO Power Safe Mode to a different value. (as described here) I did all this but still, there is no improvement.
Any other suggestions on this? Is this a known bug? Is there a patch on its way? Is Microsoft working on this?
Any help is greatly appreaciated.
Thanks a lot
Tim
2020-08-31T01:05:21+00:00 -
2020-08-30T18:27:47+00:00 This has not been resolved. This is NOT a router issue, it is an adapter issue. Ridiculous that they haven't pushed a fix. Great to have this new device that can't be used.
2020-07-28T06:09:59+00:00 Same problem and https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html seems to have solved it. Downloaded Intel's scanning tool which identified the Intel Wi-Fi 6 AX201 driver as out of date (Windows thought otherwise), updated it to version 21.90.3.2 Date 5/4/2020 - now no drop off in connection speed.
2020-07-25T14:44:29+00:00 well it's automatically install latest driver, currently it's version 21.90.3.2 date 4/5/2020
2020-07-24T15:08:43+00:00 So far with the new Intel driver I have not seen 20MB/sec speeds. I've tested maybe a dozen times so this looks good.
