Yes. The problem continues
Battery drain with Unregistered device SE?
Hi all,
Lately I've been noticing a large battery drain (at least by my standards) of ~1-2% per hour during connected standby. Based on what's advertised (7-10 days idle) I'm getting ~4 days at best? I ran the sleep study, battery report and energy report and came up with interesting results. I've also calibrated the battery and have no current pending updates. Any ideas as to why the large battery drain during standby?
Also sorry in advance for the long post. I'm not sure how to post the full reports on this forum.
Surface | Other
2014-07-12T08:43:51+00:00 -
2014-07-11T19:44:05+00:00 Hi,
Thanks for keeping us posted
After a reset, have you installed the latest updates?
You can check the update information here.
Let us know if the problems continues.
2014-07-09T19:39:54+00:00 tried. nothing. i also tried full reset repartitioning.
no results
2014-07-09T18:24:27+00:00 Hi,
Would you consider do a full reset to see if it helps?
If you would, please see here for detailed instructions.
Regard,
Clare
2014-07-07T04:24:41+00:00 I, along with others here, am reporting the exact same issue: Sleepstudy reporting Unregistered Device SE as the battery drain during connected standby on my Surface 2. I am using touch cover 1.
