not sure if there is of any help... I did some debugview tracing. Interesting is that Access Denied... It completely filled up the log.
00000023 17.13092613 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(1895)\wpncore.dll!00007FFA9CC8F465: (caller: 00007FFA9CC919BE) Exception(140) tid(1198) 80070490 Element not found.
00000024 17.13096428 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(1899)\wpncore.dll!00007FFA9CCC9165: (caller: 00007FFA9CC919BE) ReturnHr(179) tid(1198) 80070490 Element not found.
00000025 17.13096428 [15884] Msg:[onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(1895)\wpncore.dll!00007FFA9CC8F465: (caller: 00007FFA9CC919BE) Exception(140) tid(1198) 80070490 Element not found.
00000026 17.13096428 [15884] ]
00000027 17.13380241 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\endpoint\appendpoint.cpp(2605)\wpncore.dll!00007FFA9CC82332: (caller: 00007FFA9CC82E01) LogHr(4) tid(1198) 80070057 The parameter is incorrect.
00000028 17.13627434 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(964)\wpncore.dll!00007FFA9CC90CD2: (caller: 00007FFA9CC819D3) ReturnHr(180) tid(1198) 80070490 Element not found.
00000029 17.13812828 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(964)\wpncore.dll!00007FFA9CC90CD2: (caller: 00007FFA9CC8999A) ReturnHr(181) tid(1198) 80070490 Element not found.
00000030 17.14632034 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(1895)\wpncore.dll!00007FFA9CC8F465: (caller: 00007FFA9CC919BE) Exception(141) tid(25b0) 80070490 Element not found.
00000031 17.14645767 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(1899)\wpncore.dll!00007FFA9CCC9165: (caller: 00007FFA9CC919BE) ReturnHr(182) tid(25b0) 80070490 Element not found.
00000032 17.14645767 [15884] Msg:[onecoreuap\base\diagnosis\platform\notifications\platform\database\sqlitedatabase.cpp(1895)\wpncore.dll!00007FFA9CC8F465: (caller: 00007FFA9CC919BE) Exception(141) tid(25b0) 80070490 Element not found.
00000033 17.14645767 [15884] ]
00000034 17.14666748 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\database\databasehelpers.cpp(133)\wpncore.dll!00007FFA9CC85129: (caller: 00007FFA9CCAB0F6) ReturnHr(183) tid(25b0) 80070490 Element not found.
00000035 17.15294456 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\ui\toastforwardingwork.cpp(167)\wpncore.dll!00007FFA9CC745CE: (caller: 00007FFA9CC74826) Exception(142) tid(1198) 80040105 CallContext:[\WnsAFCToastForwarding]
00000036 17.15299416 [15884] onecoreuap\base\diagnosis\platform\notifications\platform\ui\toastforwardingwork.cpp(76)\wpncore.dll!00007FFA9CCC632F: (caller: 00007FFA9CC92EF0) ReturnHr(184) tid(1198) 80040105 Msg:[Failed to create activity from toast --
00000037 17.15299416 [15884] ] CallContext:[\WnsAFCToastForwarding]
00000038 17.16407394 [15884] onecoreuap\shell\shcore\libs\stream\managedcreatefile.cpp(1359)\shcore.dll!00007FFABB77A4A4: (caller: 00007FFAB9E388D3) ReturnHr(1) tid(1198) 80070005 Access is denied.
00000039 17.16420364 [15884] onecoreuap\shell\shcore\libs\stream\managedcreatefile.cpp(1383)\shcore.dll!00007FFABB77A315: (caller: 00007FFABB784F92) ReturnHr(2) tid(22fc) 80070005 Access is denied.
00000040 17.16466904 [15884] onecoreuap\shell\shcore\libs\stream\managedcreatefile.cpp(1359)\shcore.dll!00007FFABB77A4A4: (caller: 00007FFAB9E388D3) ReturnHr(3) tid(1198) 80070005 Access is denied.
00000041 17.16477966 [15884] onecoreuap\shell\shcore\libs\stream\managedcreatefile.cpp(1383)\shcore.dll!00007FFABB77A315: (caller: 00007FFABB784F92) ReturnHr(4) tid(22fc) 80070005 Access is denied.
00000042 17.16556168 [15884] onecoreuap\shell\shcore\libs\stream\managedcreatefile.cpp(1359)\shcore.dll!00007FFABB77A4A4: (caller: 00007FFAB9E388D3) ReturnHr(5) tid(1198) 80070005 Access is denied.
