Kinect v2 does not work with Surface Book with latest Windows 10 version1607
2017-03-13T22:04:07+00:00
Until recently I had no issues in using Kinect v2 on my Surface Book computer. Suddenly, after last week Windows and Surface Book firmware updates Kinect is not recognized anymore.
My configuration: Surface Book, i5/256
Kinect connected on the USB3 port of Surface Book
Powered either directly or via docking station
Kinect service set to use Nvidia card
Once I connect the USB cable the following happens:
  • Kinect led (from the Kinect adapter) is either orange (as no connection) or flashing white
  • After a few seconds, I get the following message popping up on the screen (message in the bottom right of the screen): "USB Device is not recognized...", followed up by the typical and infinitely repeating USB out sound
  • In Device Manager I can see under the Universal Serial Bus controllers: Unknown USB Device (Set Address Failed)
  • When I installed it first time the device was visible in the Devices, device Manager, etc. But was not starting the Kinect. After restart device was just not recognized.
What did I try?
  • from removing devices, disable, etc...
  • to reinstalling completely my Surface Book (yes... a few hours of work)
  • tested Kinect on a desktop PC - works OK
  • tested on a Surface3 even there works ok (I don't think that Surface3 has a USB 3 port... but, it works!)
  • used Kinect verifier, which as always is listing that USB device is unknown (but this is not new since I had it in the past too)
Any idea? I believe it has to do with latest Windows 10 updates, drivers and latest Surface Book update too. Thank you!
Kind regards,
Gia
    2017-12-08T17:19:12+00:00
    @microsoft
    This is really upsetting and disturbing.
    I bought this Kinect three months ago and havent been able to do dev with it once on my Surface Book.  Which was almost $4000.
    And now I cant even return the kinect.  Microsoft should take it back and refund me my money.
    Totally unacceptable.
    2017-11-22T13:29:26+00:00
    @Dwight,
    this Regitry Setting didn't fix the issue.
    I use on my Surface Book Windows 10 Enterprise with Build 16299 (last Patchlevel) and have installed the last Surface Book Firmware.
    Kinect Configuration Verifyer Shows only a warning on "USB 3.0 Driver" but "Verify Kinect Depth and Color Streams" Show that all fine.
    The "3D Scan" App from Microsoft always Show "Depth sensor not found"
    On my PC (non Microsoft Device) Kinect 3D scan works. So it's only a Surface Driver Problem.
    I can not understand why Microsoft does not get compatibility with their own products.
    The Surface is a very expensive device, but due to such compatibility issues, Microsoft's customers are forced to use other products without the "Microsoft Label".
    2017-10-24T03:33:11+00:00
    2017-03-14T18:09:14+00:00
    Hi Michelle,
    although it is about Kinect which is usually an accessory for Xbox, it Is actually used for other purpose that gaming. It is used in conjunction with Visual Studio for gesture recognition application.
    To me, it is about a device which was working well until new Surface Book and Windows drivers started to conflict with it.
    Could you please confirm that even in this case I should address my support request to xbox forum?
    Many thanks!
    Gia
    2017-03-14T00:07:16+00:00
    Hi Gia,
    We recommend reaching out to our Xbox support to assist you better with this concern.
    Feel free to get back to us if you have other concerns. We'll be happy to assist.
