Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-11-01T15:18:32+00:00
    I had/have the same issue. It was so crazy that I brought my first SP2 back yesterday to best buy to get a replacement.
    On the new one I again see the same issue this morning that it restarted from a unexpected shutdown.
    I'm thinking about resetting my SP2 and then work for a little bit with it, without installing the firmware update and see if it then still happens.
    2013-11-01T10:29:07+00:00
    Also if you reset any surface pro 2 and perform windows updates you end up with an UNKNOWN DEVICE in device manager call Surface Cover Telemetry and you are unable to install a driver for it.
    That's the firmware update that causes the unknown devices problem.
    I keep repeating this in other threads, so I'm sorry if you've already read it, but my suggestion, at least for now, is to not install the firmware update until we've received clarification from Microsoft that any issues within it have been resolved. I've had nothing but trouble with the firmware update. Without it, I have no problems at all.
    And, no one from Microsoft has told me otherwise so far ... *cue Microsoft response*
    2013-11-01T09:01:29+00:00
    There's definitely a problem with the latest firmware update (my SP2 shows a published date of October 24th).
    When I installed it, I lost my wireless adapter.
    I restored my device, and installed everything but the firmware update and it's running fine now.
    Any official news from Microsoft yet about these problems?
    2013-11-01T06:24:21+00:00
    Same problem here.  Surface pro 2 256g.  Was working fine with firmware update, then after a couple of days, my screen would not come back up after going to sleep.  I was able to repeat the issue many times.  There was no 'unknown device' in device manager, though.  I finally, got frustrated and wiped my surface back to factory default.  After immediately applying the firmware update, my nic card was not found and telemetry, too.  Kind of frustrating....After searching a solution for this, I'm glad I ran into this thread, cause I was about to return my surface!
