Greetings all,
Please download and install the Surface Pro 2 System Firmware Update for March 11th. This is targeted towards the Telemetry Driver:
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update. I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card. This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card. The 2 marvell drivers listed had exactly the same name. However, only choosing and applying the second one worked. So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry". However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager. I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet. I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button. When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds. However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem? And if so, where can I download a driver that works?
Thanks.
Greetings all,
That is all interesting - but not helpful: I left my surface pro 2 all alone, do its thing. Set updates to automatic download and install. But still: I have the unknown device which turns out to be surface cover telemetry and can not install a driver for it (mind you, I do not own or use a type cover).
The december firmware update at first failed to install, then i completely reset srface pro 2, let everyrhing install automatically, and then the december firmware was ok. But (it seems) since then i have the unknown device issue. + surface wakes up from sleep / energy saving even when it is just sitting in my bag, and surface keeps nagging me to install oct 23 update (since dec firmware issue I stopped automatic dl and install of updates...). And when I do install that update, voila I have the wireless unknown issue. I solved that by rolling back the oct 23 update.
BUT: DEAR MICROSOFT PLEASE OFFICIALLY SOLVE THE ISSUE OR ADVISE ON WHAT TO DO. I need my surface pro 2 for work, I thought and think it is ideal, but I will not be forced to follow other users' work arounds which may or may not solve the issues. THAT is not what I paid for.
And now dec 13 update is pulled... And how should we feel, how will we be helped who installed this botched (?) fw update???
Related to this, the official MS Support Twitter account is also ignoring me. Seems to be corporate policy to ignore problems to which currently no solution exists.
Theres still no official patch to solve this?!?! I SHOULD HAVE BOUGHT A MACBOOK AIR......
I have a Surface Pro and after updating to garbage 8.1 I started encountering all the problems that SP2 users were experiencing. This is after buying the device on release day and not having a single issue. ZERO.
All my problems were solved after resetting the device to 8.0 and not updating to garbage 8.1 again. Everything is flawless once again.
