Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-12-29T11:34:07+00:00
    I never reinstalled anything.  I just booted into driver mode then booted back in normal mode and it fixed my issues.
    Now keep in mind that I have not done any extra driver installs.  Here is my sequence.
    Reset machine
    Run updates
     ..... Get Errors
    Boot in Driver mode
    Boot in normal mode
    .... No Errors
    Im running a 512K surface Pro 2.
    2013-12-29T11:16:58+00:00
    OK I had the same problem and decided to try something that was so simple but seems to have worked.
    I had the same problem with the telemetry driver issue and my system was running at 20% CPU usage all the time and it was killing the battery.  I decided tot try booking in driver update mode (Option 7).
    I did so and the CPU usage went back down to 0% when idle. The driver issue is now fixed.  I rebooted back to normal mode and the problem is fixed.
    It looks like Microsoft used an unsigned driver in last update.
    I hope this helps others.
    Just tried: I rebooted in driver mode (option 7) and re-installed the drivers of the two unknown devices. Nothing changed: Windows tell the drivers are successfully installed, but the two devices are still pictured as unknown...
    2013-12-29T06:53:39+00:00
    2013-12-27T23:25:47+00:00
    I also had the telemetry driver issue, but above all the keys on my Type Cover 2 were not working! I reset the SP2 but nothing changed.
    Then a couple of days ago Windows Update re-installed the firmware update from Oct 24 (the first time it was installed right after the reset).
    Since then the type cover works, however now in the device manager I see 2 "other devices" without exclamation marks: 1 unrecognized device and 1 called SurfaceTypeCover_01. When forcing the driver update, Windows says the first one is successfully installed as Surface Cover Telemetry, and the second one is installed as Surface Cover Audio. Afterwards, however, the two devices are still seen as unrecognized.
    This was exactly the situation I was in. My resolution did not involve a reset.
    You need to refresh your Surface and do not apply any updates. In device manager you will probably see unknown devices.
    Download the October update and unpack it. Install the telemetry driver and the touch and type cover firmware updates manually then reboot.
    The device manager should be clear of unknown devices. You can then let Windows Update perform all updates normally and you should be fine from then on.
    Thanks to both you and Zuldan for the tips. I'm not keen on resetting my SP2 for the fourth time, since I already started installing applications and importing data! I'm sure MS will fix this issue soon, or if not, I'll go on with one of the above solutions.
    However at this point I wonder what's the actual effect of making these devices recognized. Or better, what is that is not working otherwise? If I exclude the "bad looking" device manager, I don't seem to find any issue currently with my Type Cover 2.
