Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-12-27T16:12:46+00:00
    I agree, some kind f compensation (given the facts) would go a long way. It doesn't negate other people's responses about how this shouldn't have happened in the first place, or how they might change the SP2 for a competitor device, but doe those of us who have had to spend time either solving the issue, or fixing it, compensation from MS would go a long way to repairing the bad will that this has caused
    2013-12-27T16:09:08+00:00
    You're right of course, and my original comment about new tech glitches isn't an excuse; it's more of an observation that isn't the reserve of Microsoft but features among many tech giants. It shouldn't happen and the sad thing is that the SP2 was working fine (relatively) until the updates, which have made things worse and not better. A bitter irony and something that Microsoft should never allow to happen if it wants to claw back market share and the reputational high ground. Rant away I say... Hopefully MS will begin to take note. BlackBerry purposefully did not read the forums and respond in kind to their customer complaints which ultimately led to their collapse... It was reminiscent of a cultural snobbery that led to them thinking they knew what customers needed better than the customers themselves. I do hope MS don't follow suit. There's no indication of this yet but MS: listen to your customers, support your customers and please don't listen to the pundits.
    2013-12-27T13:55:38+00:00
    Run the command prompt as an admin (e.g. via right click on the windows button) and type in: "powercfg.exe -hibernate on", hit enter and see whether hibernate reappears.
    2013-12-27T12:07:25+00:00
    I am unfortunately now a part of your club.
    I have a SP2 that never experienced any of these issues. It was always flawless.
    After the December update I had an issue with the on-screen keyboard popping up even with the type cover attached.
    After three sessions with tech support from MS via Chat, I dealt with someone named Yana who told me a refresh would fix my issue. I pointed her to this thread and told her I didn't want to end up with the issue others had. She told me she fixed other people with my problem by doing a refresh and told me not to worry.
    Right.
    I did the refresh, and the first time, I lost networking, Bluetooth, and the ability to use touch and type covers and had the failed telemetry drivers like so many others.
    I refreshed again and used the powerscript with the downloaded Oct update driver pack and now everything seems to be working, except I shut down my Surface last night, and this morning when I turned it on the battery was completely dead.
    I have no unknown or misbehaving HW in device manager at this time, but strangely I cannot enable Hibernate anymore from control panel. In fact I cannot change any of the shutdown settings. I can't un-select sleep, nor can I select Hibernate.
    Is this all related somehow?
    Thanks. Previously happy, now confused and concerned customer....
