Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-11-29T05:34:34+00:00
    Well, let's see, here's a few more issues with the Surface Pro 2 I've come across. As I've stated previously, I returned my factory reset Surface for one that I have yet to reset (thankfully). I have, however, still been unable to use the touch cover because it causes too many "sleep" problems. A few other bugs I've noticed are: 1) after printing something (to a WiFi connected printer) from the desktop version of Internet Explorer the entire display "zooms" out and everything is smaller on the screen. Closing and reopening the IE fixes it. 2) After connecting a Bluetooth headset my internet speed decreases dramatically. Apparently others with similar problems say that some Bluetooth devices do this and others don't. 3) After performing a "clean disk", it must delete an update because when I check for updates it will reinstall the same update again and again.
    As I've said in my previous post, the Surface Pro 2 is potentially an amazing device, yet seemingly almost every other day I find a new bug here and there. I've owned lots of different computers, none of which have been made by Microsoft until the Surface Pro 2. When I bought it I thought "I bet it'll work great considering its made by the giant in the industry", yet lately I've been quite sad.
    2013-11-28T22:44:56+00:00
    I was trying to hold out for a MS fix, but apparently that is going to talk quite some time...they must be engaged in fixing my dead Xbox One Kinect (not having too much luck with MS lately). The updated fix info from davidb1234 on November 10, (page 7) fixed all my issues and I am again happy with my SP2.
    HAPPY THANKSGIVING
    2013-11-27T21:38:13+00:00
    Perhaps I found a dirty way that doesn't need a factory reset.
    I were trying to download the deployment guide, then, after pressing the download button I was asked to choose the download file. Then I choosed "Octorber2013SurfaceProWin8.1.zip". This file contains all the surface drivers.
    The link is this, I think there is something more direct but this worked for me.
    http://www.microsoft.com/en-us/download/details.aspx?id=38826
    Unzip the file, select the unknown device from the device view and update manually the driver.
    Now my touch cover works for me. I hope this experience is useful to someone else.
    Thanks for your help but this method does not work at all and I am sure several people including myself can confirm this.
    2013-11-27T17:32:41+00:00
