Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-11-26T15:11:19+00:00
    Simple fact is, Microsoft needs to fix this!! This is simply unacceptable especially when they are pushing this device to mass market.
    2013-11-26T13:45:33+00:00
    Dam i put way to much trust in
    http://systemsadminguy.wordpress.com/2013/11/16/how-to-update-surface-pro-2-recovery-image-drivers/
    I double checked everything and it all seemed fine but final reset part - said there was a problem
    Now im black bios screen i guess and its stuffed :¬(
    i have an original usb recovery device i kept hope it works
    P.S. i though it might be because i used the USA version of the October driver pack but doing a binary compare...
    http://www.microsoft.com/en-us/download/details.aspx?id=40856
    is the same as...
    http://www.microsoft.com/en-gb/download/confirmation.aspx?id=40856
    So its not that
    P.P.S
    davidb1234 idea on page 7 worked fine so im ok now PHEW!
    common Microsoft play nice
    2013-11-26T05:44:50+00:00
    Tried that already as mentioned above. Got werid driver issues with other drivers and the News app started crashing.
    I know this is going to sound weird and not related but can you tell me the exact version of wireless adapter driver you currently have installed?
    2013-11-26T01:37:50+00:00
    SanAndreaz, try this fix. It may resolve all your issues having the latest drivers when your SP2 is reset.
