Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-11-12T17:45:48+00:00
    You're welcome.
    I guess we just saved MS hundreds or thousands of device returns.
    I'm glad you have resolution.   But, why do you think everyone does not have this problem?  I've factory Reset.  I've not seen this issue.  I've done it a couple of times...never an unknown device.  I've seen threads with 128g models and 256 models and 512g models.  So, it obviously impacts more than just 1 model.  But why not everyone?   Maybe lots?  Or user issues?  Any thoughts?
    2013-11-12T03:36:24+00:00
    You're welcome.
    2013-11-10T23:56:21+00:00
    What worked for me was a combo of suggestions.  After the reset, restored functionality to Telemetry by using the Oct. Driver Update and "install" via the INF, not letting Device Manager find the driver.  Then I did the same for the Touch Keyboard and Type Keyboard, to be safe.
    The Telemetry portion was marked as unknown right after the reset.
    Finally, took all the updates, incl. the 8.1 FW update.  Noticed hat wi-fi and BT were not working, but as noted early, disabled and reenabled the offending adapter and it was working fine thereafter.
    This does not give me a warm fuzzy about MS tho.
    2013-11-10T21:44:01+00:00
    Finally! One that works! I can confirm this worked on my SP2 256GB. I appreciate all the help!
