Battery drain issue
2020-02-06T02:43:57+00:00
Hi all,
I just got a Surface Pro 7 and became a part of Surface community.
I have a quick question. How long does your Surface Pro 7 battery last?
I saw several posts and comments on the battery drain issue, but I'd like to know whether the battery problem is only to a specific model (i5 or i7), or just seen in some devices.
Because I feel my Surface Pro barely works for 4~5 hours (Wifi with google docs, or simple work, etc.) not up to 10.5 hours. On the ads, it clearly says 'All-day battery life' & up to 10.5 hours of typical device usage. I tried some recommendations from other posts, but so far no luck here.
So, I'd like to know whether you have a similar problem or successfully managed the problem.
Thanks in advance.
    2021-05-10T23:01:38+00:00
    I actually have both devices and 4-5 hours on Surface Pro 7 is max you can get on a dimmed screen with power saving turned on when on M1 macbook air i am able to work like 13-16 hours without even thinking about the battery ;) Just like Thomas wrote - great device but battery... it's damn joke.
    2021-05-10T22:41:54+00:00
    I am not sure what you are talking about. I am also getting about 4, for basic office tasks on my SP7. I have been very disappointed. Great device but absolutely garbage battery life.
    2021-05-10T21:49:36+00:00
    Not sure what you are talking about.  My SP7 gets over 8 hours of continuous YouTube viewing at 50% brightness with battery saver on.  As for the M1 chip, it is seriously over-hyped and has made MBs on par with, not better than, Windows laptops ( https://www.laptopmag.com/articles/all-day-strong-longest-lasting-notebooks ).  Finally, please let me know when Apple makes a computer-table hybrid or even a 2-in-1 like MS, Dell, Lenovo, ASUS, Huawei, etc.  Otherwise, no point in bring Apple and their 20th-century hardware into the conservation.
    2021-05-10T09:22:38+00:00
    I have a surface pro 6 without any battery life issue. I wanted to upgrade and I didn't get the surface pro 7 after reading the reviews of poor battery life. I waited to get the surface pro 7+ with the 11th gen of intel i7, as it was supposed to fix the battery life issue. What a disappointment! Very poor battery life. I don't get 4 hours with light use. I guess, Microsoft needs to catch up with Apple and install M1 or ARM chips, as Intel are battery hogs
    2021-01-26T12:56:41+00:00
    Exactly the same issue. I'm afraid this will stop me from getting a microsoft laptop etc. for another 5 years at least.
