I use the "Pure Battery" app from the Windows store. It is excellent.
Battery drain issue
Hi all,
I just got a Surface Pro 7 and became a part of Surface community.
I have a quick question. How long does your Surface Pro 7 battery last?
I saw several posts and comments on the battery drain issue, but I'd like to know whether the battery problem is only to a specific model (i5 or i7), or just seen in some devices.
Because I feel my Surface Pro barely works for 4~5 hours (Wifi with google docs, or simple work, etc.) not up to 10.5 hours. On the ads, it clearly says 'All-day battery life' & up to 10.5 hours of typical device usage. I tried some recommendations from other posts, but so far no luck here.
So, I'd like to know whether you have a similar problem or successfully managed the problem.
Thanks in advance.
2022-01-31T18:08:49+00:00 -
2022-01-30T16:31:17+00:00 I'm having a similar experience. When I first got it, the battery lasted longer. Now it feels like 4 - 5 hours on a fully charged battery.
2021-11-22T13:20:42+00:00 Same battery is so weak ..feels like laptop was better . 4 -5 hrs in streaming videos
2021-10-05T23:03:47+00:00 Thanks for your instruction! I think I will test my Surface Pro 7 for a few days, if the battery still drains fast, then I will ask for exchange. Right now it lasts for about 6 hours .
No problem, glad I could help also you might to check to see what background apps are running and turn them off if not needed.
2021-10-05T20:38:42+00:00 Thanks for your instruction! I think I will test my Surface Pro 7 for a few days, if the battery still drains fast, then I will ask for exchange. Right now it lasts for about 6 hours .
