Surface 4 Pro screen bulging at lower left edge and separated from the frame
2017-11-04T20:36:18+00:00
I have a Surface 4 Pro that I purchased in March 2016. Over the last few days, I was seeing a considerable color bleed on lower left edge of the screen. Then I stared noticing that that type cover does not seem to close flat against the screen. On closer inspection, I found that the screen is bulging (curving out) on the lower left side and the screen edge has separated from the frame, exposing a gap, Some of the circuitry inside seems to be pushing out as well from what I can see through the gap, indicating something inside is exerting an outward pressure. I pushed the screen back in and with a little pressure it got flattened. However, after a few minutes use, the screen bulged out again. There is no physical damage to the screen, the bezel or the device in general, no cracks or scratches.
What is causing this and what is a possible solution?
Deepak
    2021-08-05T20:19:17+00:00
    Deepak simply read some of the 25 pages before your post and you'll soon see we all suffer from this expanding battery problem that MS do not acknowledge or address. Short answer your Surface is stuffed, or soon will be and don't buy another.
    Simple
    Sadly
    2021-08-05T19:20:35+00:00
    Deepak
    2021-07-27T14:59:33+00:00
    I got this on my lenovo ideapad 330s 15kb the screen is fine but when I open it, it makes a crack sound
    2021-06-18T16:21:43+00:00
    Yep and who can blame you/us for switching away from MS when the support is so p*ss poor.  Its pretty clear that they don't read these forums either or would have sprung into corrective action long ago; at least long before we reached 26 pages of complaining about battery bulges and **** service regarding them.
    Ah well back to my non MS products that work properly!!  And no I haven't succumbed to the controlling world that is everything Apple, but it was close...
    Surface  RIP
    2021-06-18T11:55:06+00:00
    got 5 surfaces pro 4 at work for our commercials,   all 5 units got the same problem , one at 3yo at the rest at 4yo,   microsoft have a very poorly hardware design,   first they put wifi near usb without isolation, meaning that any usb 3.0 will cutoff wifi at 2,5ghz, so we were forced to update our routers to 5Ghz,  then microsoft oficial bases didnt work at all at beginning, lots of problems, solved 2 years ago with countless firmwares updates.
    and then to finish microsoft rep,  all our tablets have the display problem.   since then we banned any microsoft hardware from our office,  and we changed for XPS laptops.
