I've never used a dock with my Surface Pro 4....
Surface 4 Pro screen bulging at lower left edge and separated from the frame
I have a Surface 4 Pro that I purchased in March 2016. Over the last few days, I was seeing a considerable color bleed on lower left edge of the screen. Then I stared noticing that that type cover does not seem to close flat against the screen. On closer inspection, I found that the screen is bulging (curving out) on the lower left side and the screen edge has separated from the frame, exposing a gap, Some of the circuitry inside seems to be pushing out as well from what I can see through the gap, indicating something inside is exerting an outward pressure. I pushed the screen back in and with a little pressure it got flattened. However, after a few minutes use, the screen bulged out again. There is no physical damage to the screen, the bezel or the device in general, no cracks or scratches.
What is causing this and what is a possible solution?
Deepak
2020-07-04T02:22:36+00:00 -
2020-07-02T22:34:43+00:00 Are you still within the warranty or out of warranty?
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2020-06-28T09:46:14+00:00 You should change this Facebook group to a public group. Might get more
participation. -
2020-06-28T09:44:13+00:00 Yes.
Glad someone has the motivation to take on microsoft stome walling.
i suspect this company is on the way out and the old folks are just counting their profits.
2020-06-24T12:27:37+00:00 Many thanks, Robert, for this helpful advice.
