Surface 4 Pro screen bulging at lower left edge and separated from the frame
2017-11-04T20:36:18+00:00
I have a Surface 4 Pro that I purchased in March 2016. Over the last few days, I was seeing a considerable color bleed on lower left edge of the screen. Then I stared noticing that that type cover does not seem to close flat against the screen. On closer inspection, I found that the screen is bulging (curving out) on the lower left side and the screen edge has separated from the frame, exposing a gap, Some of the circuitry inside seems to be pushing out as well from what I can see through the gap, indicating something inside is exerting an outward pressure. I pushed the screen back in and with a little pressure it got flattened. However, after a few minutes use, the screen bulged out again. There is no physical damage to the screen, the bezel or the device in general, no cracks or scratches.
What is causing this and what is a possible solution?
Deepak
    2019-11-20T18:55:27+00:00
    Sadly I don't think so. It does not make sense calling Microsoft in a different country from where you live.
    Again, we're having different/ inconsistent responses from Microsoft on the same issue :)
    2019-11-20T18:37:40+00:00
    Try to call here in USA maybe they will instruct you what to do ....
    2019-11-20T18:16:57+00:00
    I don't think so they will pay your airplane ticket...
    2019-11-20T09:35:15+00:00
    Lucky you.
    When I called Microsoft France and tried to escalate the issue, they said that "You can call any other Microsoft offices, you will get the same reply everywhere". They could not exchange my device for free, I had to pay.
    Again, I think specifically for this issue, they should waive the 3 year extended warranty period. I don't know if it has anything to do with Microsoft is still pretty much a US-centric company (my perception)
    2019-11-20T09:06:03+00:00
    Do you think they’ll pay for my airfare to usa from australia and reverse what i had to pay for a refurbished surfacepro4.
    They are idiosyncratic if not idiotic in their responses.
    Pleased for you.
    Good for you.
    An idiosyncratic dinosaur of a company.
