Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-21T06:04:44+00:00
    Thanks for the heads up. Sounds great. You can test the 75% issue by just doing a (real) reboot or even better: shutting down your Surface with being unplugged. Overnight is not neccessary. Maybe you could do that for us. No standby or hibernate. Just shutting it down while unplugged and then starting it again still being unplugged. Just takes 1 minute. Thanks.
    2019-09-21T05:43:24+00:00
    I can't tell you about the 75% issue, as I leave my SP6 plugged in overnight. I had a correlating issue however in which when I unhook in the morning my battery would read 100% for an hour, and then proceed to drain at an insane speed, leaving me with only 2 hours of battery life. This has been fixed completely with the new Insider update and I've done around 4 battery cycles so far.
    2019-09-21T05:40:59+00:00
    Rory, did this update fix the 75% battery issue? Does your battery last longer now overall? Please tell us. Thanks!
    2019-09-21T04:44:47+00:00
    Keep checking for available updates. The fix isnt in 18985.1.
    You should see
    Surface - Firmware - 9/4/2019 12:00:00 AM - 241.1.139.0
    in your pending update list.
    Make sure your insider settings is set to "Skip - Skip ahead to the next version of windows"
