Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-11T12:13:34+00:00
    Did anyone get a replacement for Surface Laptop 2 in Europe (Germany return center)? If so, did you receive a new or used unit?
    I've shipped my SL2 for replacement for this battery issue (not planning to update the firmware until it's fixed) and a dead pixel.
  2. Deleted
    2019-09-10T18:22:19+00:00
    CORRECTION...
    Maybe it worked after all.
    I turned the unit off last night with 100% charge remaining, and this morning I turned it on and it was still at 100%...
    We shall see if it holds...
    2019-09-10T13:22:03+00:00
    Is this a Surface specific issue, or is it also related to the Intel power management bug? I'm just curious 🤔
    What's the Intel power management bug?
