Surface Pro 2 system issues
2018-07-18T17:10:07+00:00
I am running a Surface Pro 2 with build 17134.167.  There is an external USB HUB with a Dell monitor, mouse and audio connected to the HUB.  After the last 1803 update, the display driver fails to load and the external display is not recognized, although it works.  The Control Panel Device Manager also shows that the unit is not recognized as a Surface model with the keyboard and unit displaying caution icons.  Associated drivers imply that they are for a Surface Pro 4.  The system appears to work, but it has issues.  All updates have been through automatic updates, so I do not understand the Surface Pro 4 designations.
I have tried to update drivers when allowed and that fails with the system telling me that the installed drivers are up to date.
Am I doomed to perform a reinstall, or is there another solution.  Evidentially I have no recovery files, although I am sure that I made some.
    2018-07-23T21:58:29+00:00
    If using wmic:root\cli>csproduct list full:
    Description=Computer System Product
    IdentifyingNumber=[Redacted]
    Name=Surface Pro 4
    SKUNumber=
    UUID=38BEF5F5-9784-6644-4F3E-C91730606056
    Vendor=Microsoft Corporation
    Version=D:0B:08F:1C:03P:38
    2018-07-23T21:55:31+00:00
    Robert,
    Under ChassisSKUNumber, I get:  CIM_String   <NULL>
    Under Model, I get:                       CIM_String    Surface Pro 4
    Under SystemSKUNumber I get:   CIM_String    Surface Pro 4
    2018-07-23T17:27:59+00:00
    I installed the SurfaceProUEFI.inf.  The system claimed that the installation was successful, but that message came back almost immediately.  I'm an old EE and I know that it takes longer than that to flash a ROM.  I did the reboot and nothing had changed.  Noting this lack of success, I didn't bother with the other two.
    I imagine there could be other changes from doing that, e.g. registry and file changes, so then doing the other two could cause further differences.   To try to find out the full effect you could trace each one with ProcMon, filtering with Category Is Write.  If you are at the point of re-imaging you should have nothing to lose by being more radical with your experiments.  For example, in particular, I would be optimistic about seeing something useful happen from doing the deletes in WMIC that I mentioned.
    Serendipity.   Searching on this tack I have just learned about  WBEMTEST  as a more complete diagnostic.  For example, after following the instructions in the answer of this thread I found that I have
    ChassisSKUNumber  CIM_STRING  Surface_Pro_2
    What's yours?
    https://social.technet.microsoft.com/Forums/systemcenter/en-US/6c0668db-b3e8-4515-a0a4-b2a73304babf/csproduct-get-name-not-returning-model
    (BING search for
        site:technet.microsoft.com wmic delete aliases BIOS CSPRODUCT
    Good luck
    Robert
  4. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2018-07-23T14:39:21+00:00
    They would direct you to open a support case (which would result in them telling
    you to reimage the device as a first step). And you can't even exchange a
    Surface Pro 2 as it is marked as discontinued and there is a sticky posted at
    the top of this forum about changes in support stating Microsoft reps will no
    longer provide technical replies in SP2. MY interpretation is that Microsoft is
    sending a not so subtle message.
    I'm sorry..
    >Is there no one at MS that you could tap to get any insight?
    2018-07-23T14:03:09+00:00
    The official recovery image solution may be my only recourse.  My problem is that once I got the system sane again, I'd have to reload all of the software I've amassed over the years.  Biggest issue would be my copy of Office 2007 Pro.  I'd have to interface with MS to get that mounted due to its age and that I've had it on several past computers.  Everything I could recreate over time.  Should look at it as a good time to house clean.  It's just the pain of it all.
